broken drive = sunk boat? 2002 cig 38 >
Old 07-24-2014 | 08:58 PM
jeff32's Avatar
Default broken drive = sunk boat? 2002 cig 38
is this something I can think of, when a drive 'disapear' like that?
when looking at picture of the gas tank, looks like sand or something like that...
why just a broken drive would lead into a project?
http://www.offshoreonly.com/classifi...o58099-en.html
jeff32 is offline
Old 07-24-2014 | 09:07 PM
Looks like foam with mildew between the tanks
JRider is offline
Old 07-24-2014 | 09:17 PM
I think that is foam not sand it does look like sand.
LOTOWONTOPGUN is offline
Old 07-24-2014 | 10:14 PM
Same stuff thats between my tanks, foam.Perfectly normal
ICDEDPPL is offline
Old 07-24-2014 | 10:19 PM
VP of the tickfaw200
Yep that's foam all boats or most with alum tanks held in place by foam. If the foam is separated from the tanks that could be bad. Would let water seep under them if the floor wasn't sealed well.
caseyh is offline
Old 07-24-2014 | 10:30 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
ANOTHER Crayola Cigarette?
https://www.youtube.com/watch?v=fK5WnU75naQ
Sydwayz is offline
Old 07-24-2014 | 10:37 PM
Why does each tank have two pickups and 3 fuel delivery lines out?
242LS is offline
Old 07-25-2014 | 06:19 AM
dcb
You can switch the valves to allow the engines to draw off either tank, normal setup is one engine drawing off one tank.
dcb is offline
Old 07-25-2014 | 06:41 AM
Too bad the paint and interior are awful.
TBAG is offline
Old 07-25-2014 | 07:14 AM
still seems like a decent boat for the money
pstorti is offline
