454 Cam selection down sizing? >
Old 07-27-2014 | 02:13 PM
Default 454 Cam selection down sizing?
I have a fresh short block 454 with 10.1 compression. Which I am selling to my buddy to help him get back on the water asap. We are trying to put together I a motor using parts we currently have. Going to be using GM 088 Heads. We are trying to decide what Cam to use. I have a Mercruiser 454 Mag cam and a Comp marine 11-306-4. Can I get away with a moderate cam like one of these? Not looking for the extra power, Just want it to run good. Also want to be able to use stock exhaust and stock rocker arms.
Satisfaction is offline
Old 07-27-2014 | 05:30 PM
how did you achieve 10-1 compression on that motor. You need to run a little larger cam with that compression
motor is offline
Old 07-27-2014 | 05:34 PM
SB
That's a whole lot of want.......
Does it make 10:1 with those heads ? I'd measure everything that effects compression and see what it really will have.
SB is offline
Old 07-27-2014 | 07:09 PM
if the pistons have a little dome,,it will.
sutphen 30 is offline
Old 07-28-2014 | 01:35 AM
The comp cam has a 110 Lob sep and will not work with stock exhaust. It will revert water.
Use thick head gaskets to reduce compression as much a possible and the stock 454mag cam.
Griff is offline
Old 07-28-2014 | 07:15 AM
Any good Thick Marine Head gaskets out there?
The pistons are SRP 212135
(118cc @ 9.9-1)
Was planning on using Fel-Pro Head gaskets FEL-17042
Which according to my calculations puts it at 9.8 to 1
Old 07-28-2014 | 07:27 AM
If you go with an extra thick head gasket, then your quench numbers go out the window, which in itself could promote detonation. 10:1 on an iron-headed marine engine is asking for trouble, unless you plan to run racing fuel in it. Better break out the Valdez Platinum Card for that one with a boat. I tried to compromise on my 454 years ago - had a set of domed pistons that would have produced similar CR numbers. Jumped through hoops to make them work - had the domes milled down, thicker head gasket, etc. In the end, the engine eventually succumbed to detonation and busted the ringlands off two pistons right near the valve reliefs. IMO trying to throw together a motor for a boat with "parts laying around" is a gamble at best. You can get away with it on a car, but with a boat you might as well belly up to the roulette table. A marine engine needs to be thought out with carefully selected parts that work together within the rigid parameters that a marine environment dictates. Sorry I don't have more help than that, but I wish you the best of luck.
Budman II is offline
Old 07-28-2014 | 08:22 AM
Everyone thanks For all the very helpful information!
I didn’t mean it so much as piecing it together. It turns out my buddy wiped out the short block on his 454 Mag. And I have a 454 10-1 short block. That I have no use for, and would like to use if possible. Anything that can/needs to be done to make this work?
I just wanted to get some feedback on possible use of what I already have before spending the extra money on another short block.
Old 07-28-2014 | 10:49 AM
the only thing you MAYBE could do id get a custom cam but I still think youre going to have detonation problems
Gh700xx is offline
Old 07-28-2014 | 11:31 AM
What's your guys thoughts on using comp marine 11-306-4 cam and upgrading the exhaust?
