Could backfiring cause this? >
Old 07-27-2014 | 08:02 PM
Randy Nielsen's Avatar
Default Could backfiring cause this?
[ATTACH=CONFIG]526817[/ATTACH][ATTACH=CONFIG]526818[/ATTACH][ATTACH=CONFIG]526819[/ATTACH]
Attached Thumbnails Could backfiring cause this?-20140727_151151.jpg   Could backfiring cause this?-20140727_150737.jpg   Could backfiring cause this?-20140727_150711.jpg
Randy Nielsen is offline
Old 07-27-2014 | 08:05 PM
What happened?
Jonesyfxr is offline
Old 07-27-2014 | 08:34 PM
Long story short, engine was assembled, dyno'd, & tuned ran great. Installed in boat plug wires got crossed (don't ask) tried to start it was backfiring bad, got wires straightened out starts & runs but vibrates anything above idle. Checked timing, valves, carb, nothing wrong. pulled engine, pulled pan slight amount of I assumed assembly sludge, pulled #2 rod cap and #3 main to look & the pics are of what I found. Gen VI 502 .030 over aftermarket crank stock gm rods mild 515hp build. Approx 1 hour run time after dyno tuning.
Old 07-27-2014 | 09:45 PM
A good backfire could cause a balancing issue.
Old 07-27-2014 | 10:42 PM
randy,if you run your fingernail across the journal can you feel anything because from looking at the pick it looks ok.
mike tkach is offline
Old 07-27-2014 | 11:43 PM
Mike, I just pulled 1 of each but yes on the main & no on the rod journal. I can't remember what brand the crank is but the one that was replaced in this engine was a scat crank & it wiped the bearings with the static compression test that was done when it was originally built by Jasper Racing, that is why I had it gone through again so I wouldn't have these problems. The crank was replaced & short block built 5 yrs ago then stored until last yr then everything disassembled cleaned up & reassembled, dyno'd now this.
Old 07-28-2014 | 12:25 AM
Can you see any ballancing weights on the crankshaft?? the viberation sounds like a ballancing issue..if they internally ballanced the engine then you will need a 396/427 harmonic ballancer and flywheel needs to ba machined off or 396/427 flywheel..
FIXX is offline
Old 07-28-2014 | 01:26 AM
Probably not an issue since it dynoed fine.
Griff is offline
Old 07-28-2014 | 03:06 AM
When they run out of oil #3 main is the first to go. I don't know how hard you were running it for an hour...
Black Baja is offline
Old 07-28-2014 | 06:44 AM
If it ran smoothly on the dyno and now vibrates after installation, maybe it's a flywheel issue?
