353 windshield removal >
Old 07-29-2014 | 07:00 AM
Default 353 windshield removal
Anyone ever take their windshield off? I want to take it off to have the frame repainted or powder coated due to corrision on frame. If anyone has done it any tips on removal?
353Formula is offline
Old 07-29-2014 | 01:46 PM
I removed the stainless steel windshield from my 1997 419 Fastec. Removed the black foam strip at the base, exposed screws, unscrewed them all (some were broken), removed the windshield as a whole. Once removed, you will have to disassemble the frame from the glass.
38fountainecman is offline
Old 07-29-2014 | 06:12 PM
RedDog382's Avatar
Yeah ... just don't break the gla$$!
RedDog382 is offline
Old 07-29-2014 | 06:20 PM
Did it this spring, same reason - new powder. Pretty easy. Mark the seals, clean them well. Also, you likely will need to bake the aluminum to have it remove any salt, assuming it's been in salt water.
Hardes part was putting the two rounded pieces in, they took about an hr each to get them right.
snowrunner is offline
Old 07-29-2014 | 08:17 PM
Thanks for the advice. I am going to do this project at the end of the season.
Old 08-03-2014 | 08:18 AM
What did you use on it powder or paint when you did it. I have access to paint booth so I am thinking paint. Also I am looking for the code that formula/ taylor made used on it so it can match it.
Old 08-04-2014 | 06:10 PM
Power will hold up better than paint on the windshield. I was going to have it sprayed until a few local repair shops told me to use powder. The aluminum is very soft, be careful with the media you use for blasting.
