Is this a Bulldog motor?
Old 08-01-2014 | 09:21 AM
Default Is this a Bulldog motor?
Can you tell from the pictures if this is a bulldog motor? What are some things to look at to verify besides getting a serial number?
http://rochester.craigslist.org/bod/4555063630.html
Vanharca is offline
Old 08-01-2014 | 09:33 AM
Dean Ferry's Avatar
Veteran: Air Force
Well it looks like a Chevy Hi-Perf. ZZ502 to me...
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 08-01-2014 | 09:36 AM
Its not a stock bulldog you will have to investigate it shoudl be a 540 cubic inch block to be a true Merc Bulldog if I remmeber they also made an HP 500 but it was not with the 540
boomer is offline
Old 08-01-2014 | 09:37 AM
Is that a marine motor? The dealer got the boat at auction and doesn't know the history, but is advertising the bulldog.
Vanharca is offline
Old 08-01-2014 | 09:39 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
This is an HP500 Bulldog from back in the day:
[ATTACH=CONFIG]527252[/ATTACH]
It could be, but you would have to look up the serial number.
Check here: www.mercruiserparts.com
Sydwayz is offline
Old 08-01-2014 | 09:43 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
It LOOKS like something out of the GM Performance motors lineup.
http://www.summitracing.com/search/p...69887%2B400129
Car motors are a lot tighter than boat motors. Car motors run at much lower RPMs vs. boat motors. You would need build specs to know exactly, but it could be a very solid platform. I have a bone stock ZZ502/502 in my jet boat, but I don't run it on the ragged edge either.
Sydwayz is offline
Old 08-01-2014 | 03:19 PM
PatriYacht's Avatar
A Bulldog is a tall deck motor. If this isn't, it's not.
PatriYacht is offline
Old 08-01-2014 | 03:34 PM
F-2 Speedy's Avatar
Hmmmm, I thought it was a stroked & bored 9.8
F-2 Speedy is offline
Old 08-01-2014 | 06:08 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Bulldog is a tall deck 4.375 stroke and 4.440 bore = 540ci .
the deep is offline
Old 08-01-2014 | 06:58 PM
BUP
Maybe this guy has an animal that's a bulldog. Thats a GM performance crate engine from the auto performance side..
I use to see the Bulldog motor back in its day but only about twice a year. I know all the OEM factory stock specs.
540 CID - 8.9 L
compression ratio 8.6:1 I think for earlier motors and later motors was 8.75:1 - I could be wrong about the 8.6 to 1
Bore & stroke 4.44 x 4.375 or 112.7 x 111.1 mm for you metric guys
Merc recommend 87 octane fuel
Merc said propshaft hp was 470 I found that hard to believe because the HP 500 NON Bulldog had the same HP.of 470
Even in the late 90's GM Mark IV tall deck "bow tie" cast iron block
4 bolt mains
Manley forged steel connecting rods
Lunati forged steel crank - 4 bolt mains
Wiseco Forged aluminum pistons - Yes Wiseco pistons
Speed Pro piston rings
Crane performance hydraulic roller cam
crane hydraulic lifters
Manley heady duty pushrods
Crane roller rocker arms
Crane valve springs the dual coil type - the weak link
Crane retainers
Dart aluminum single plane intake manifold
Holley 800 CFM Marine 4 bbl carl
GM Heads cast iron with 3 angle valve seats
Stainless steel intake valves same as the HP 500
Inconel exhaust valves same as the HP 500
diameter I would have to look it up of the valves but I remember it is the exact same and the GM heads that the HP 500 used.
Gil made exhaust for Mercruiser
Carter fuel pump - did not use the belt driven combo fuel pump / impeller pump like the HP 500 because of the Gen V & IV no fuel pump boss on the side of the block
Melling High volume oil pump
cast aluminum oil pan - forgot the capacity - If I remember correctly it was way more than the HP 500 - 8 qt stamped steel GM oil pan. I want to say 12 qts. if I recall correctly.
Mercruiser T-bolt V ignition system and like all T-bolt V's it did have the built in REV Limiter.
Mercruiser also claimed Blueprinted internal components of the Bulldog engine.
RPM range of 4800 - 5200
Hope this helps and did I forget anything ?
BUP is offline
