Jetting starting point? >
Old 08-01-2014 | 09:54 PM
Default Jetting starting point?
Pulled the blowers off and going back to N/Am that said, specs are 555CI/9.3CR and rest is HP500. Cam is a bit better than stock, factory iron heads, 800 holley carb with factory single plane intake. Jetting now is 84 front w/ 4.5 PV and 94 rears no PV. I have a wide and kit coming and risers are getting bungs in them now but curious as what my starting point should be. Any input would be appreciated.
Thanks,
Chris
endeavor1 is offline
Old 08-01-2014 | 10:37 PM
i think the jetting you have would be a safe starting point.
mike tkach is offline
Old 08-02-2014 | 12:35 AM
Thanks Mike T. I ve talked with Mild T in he past and you Chitown guys are good to go n my book. I'll update with base AFR and what it took to get the NA setting right. Idled fine N/A and dirty as a blown motor so they may be close out the gate.
