Auto Bilge Pumps
Old 08-04-2014 | 02:29 PM
Default Auto Bilge Pumps
Trying to figure out if my auto bilge pump is bad. The boat has terrible engine access, I can't see the pump, but I can see where the discharge hose goes into the bilge water, so I think there is enough water to justify a pump trip. When I turn on the switch, nothing happens other than the switch indicator turns on. What I don't understand with the auto pump (built in float) is does the float have to trip to get the pump to run, even when I select manual on? It seems to me like that is should run any time I turn the switch on?
ADub is offline
Old 08-04-2014 | 02:44 PM
Mine runs with either the built in float, or when I manually activate the switch. The indicator light is on whenever the pump is running, as it should be.
Cole2534 is offline
Old 08-04-2014 | 02:46 PM
Thats what I figured, which means mines not working. Going to a PITA getting that thing out
ADub is offline
Old 08-04-2014 | 03:17 PM
Sometime they stick when they haven't been used. I realize that it will be tough to get to, but if possible, try to take the pump out and give it a spin. If it's hard to spin initially, that may be the problem. You may be able to free it up without changing it.
Eddie
Young Performance is offline
Old 08-04-2014 | 03:56 PM
Too Stroked's Avatar
The first thing I'd do in your case is blast the bilge pump and surrounding area with a hose. Use hot water if you can. This will generally loosen up any crud that may have gathered around the pump and float switch. If that doesn't work, then try back-flushing the pump through the outlet on the side of the boat. If that doesn't work, the pump has to come out. Is it a "cartridge style" pump by chance? (They generally have a set of "ears" on the top that allows you to remove the guts of the pump pretty easily, then replace them with a new set.)
Too Stroked is offline
I'm not an expert-- could you squirt water into the outlet hose and maybe the pressure will free up the pump impeller???? just a thought before you crazy trying to get at it.
3pointstar is offline
Old 08-04-2014 | 04:37 PM
Already tried back flushing. I will try and squirt the hose down in the bilge but I cant see it. Only reason i know its there is because it used to work!
ADub is offline
Old 08-04-2014 | 05:38 PM
put another one at the front of the engine where it can be dealt with when you have a problem. run new discharge tube to the same thru hull exit. you need a new pump anyway. you can't trust your boat to a fixed-up freed-up POS that you can't get to. ignore old pump till engine comes out or exhaust off or something.
dereknkathy is offline
Old 08-04-2014 | 05:40 PM
Yes thats the plan. Not going to kill myself to get the old one out. Just like to find the harness
ADub is offline
