Grab Handle
Old 08-05-2014 | 05:48 PM
Default Grab Handle
Looking for at least one of this style of grab handle. It is 12" from the stud center to center and about 14" overall. One of the studs broke on mine.
Would prefer purple, but I'll take what I can get.
Griff is offline
Old 08-06-2014 | 02:14 PM
carter38's Avatar
I might have one I'll check if not you and usually cut the head of a bolt off and locktite it in or use all thread.
carter38 is offline
Old 08-06-2014 | 03:14 PM
That was my first thought. It actually has a bolt on the backside that's a mm away from the bend in the handle.
I tried drilling the old one out, applied a little too much pressure and the bit went through the handle.
Thanks for checking.
Griff is offline
Old 08-06-2014 | 05:48 PM
Griff.. I think I have one in stainless.. I will check when I get home tonight..
HyFive578 is offline
Old 08-06-2014 | 05:53 PM
Correction.. I found a picture of it.. let me know if this will work for you..[ATTACH=CONFIG]527481[/ATTACH]
Old 08-06-2014 | 08:53 PM
Its close, but I think its too tall. Mine is only about 2.5 inches tall and it is spread out further for an overall length of 14".
My problem is matching the other side and covering the indentations left in my vinyl on the seat back.
Griff is offline
