Removing sticker residue?
Old 08-11-2014 | 09:32 AM
Default Removing sticker residue?
So far tried diesel,gasoline,lighter fluid,nothing budged it,,
gonna try getting a can of goop-off next,,wondering if anyone has any better ideas...
something that wont melt the paint obviously,LOL..
HTRDLNCN is offline
Old 08-11-2014 | 09:36 AM
F-2 Speedy's Avatar
mineral spirits
F-2 Speedy is offline
Old 08-11-2014 | 09:50 AM
I used goop off and it worked great. Then took a buffer to the back and boom....clean and good as new.
Nate5.0 is offline
Old 08-11-2014 | 09:53 AM
if Gel-Coat, Acetone will work well. If paint, don't use Acetone.... You could also try a eraser wheel (just like it sounds, its a giant rubber eraser on a mandrel so you can use it with a drill). You can find them at most automotive paint jobbers (some auto part stores may sell them too). Also try to add a little bit of heat to the mix. A hair dryer should be enuff to soften the glue without hurting the paint/gel. If using a heat gun, be careful too much heat will blister paint and turn Gel Coat Yellow.
low_psi is offline
Old 08-11-2014 | 10:05 AM
You can use WD40 or 3M makes an adhesive remover that'll kick any glues azz....
fastdonzi is offline
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Answers here:
http://www.offshoreonly.com/forums/b...-stickers.html
Sydwayz is offline
Old 08-11-2014 | 10:20 AM
Goof Off
Fast Shafts is offline
Old 08-11-2014 | 11:11 AM
Thanks everyone!!
HTRDLNCN is offline
Old 08-11-2014 | 11:51 AM
Goo Gone
Feverz29 is offline
Old 08-11-2014 | 12:02 PM
From: East Texas Waterfront- running errands if anyone asks
Rubbing alcohol. (isopropyl) Same thing you would use to prep for new stickers.
Flightplan is offline
