Intake ?
Can you go from a rectangle port head to a Weiand blower oval port intake manifold? If you can what is the best intake gasket to use?
Not sure what you're trying to gain, but why would you want to assemble using mis-matched parts? I've always used components that were designed to work together, then "gasket-matched" my aluminum intake manifolds, and aluminum exhaust as well. I've tried to work my cast iron heads to the gaskets as well, always looking to get the best "un-interrupted" flow through the breathing portion of the engine. I don't want to be a nay sayer, but I don't see how you're going to accomplish that with mis--matched parts...
Very hard to do because most oval port intakes will not cover the top of the rectangular port openings in the head. Can you say massive vacuum leak ?
However, the Dart Single Plane Oval Port intake usually has enough height to it's head mating surface to cover the rectangular port openings on head.
And yes, many have done this.
I think one of the older Holley High Rise Dual Plane (oval port) Intakes would seal it too, but that was a long time ago, and i'm old, so that millimeter of a memory may be way wrong. Howevever, I have good memory on the Dart Single Plane Oval Port intake.
Since you deflated my sails by not giving us correct info earlier.
I'll ask now: which Weiand Blower ? They made several different sizes.
Ah, forget it.
Just call Weiand. If they have no answer - they should - then do what was said above and take the intake and lay across a rect port intake gasket and see if it will seal.
Ah, forget it.
