Slight vibration now low oil pressure >
Old 08-11-2014 | 03:31 PM
onesickpantera's Avatar
Default Slight vibration now low oil pressure
Friend's boat developed a slight vibration. Replaced u-joints and gimbal bearing and it was still there. Now oil pressure has dropped considerably. He is going to drain the oil and cut the filter for inspection. But, in the mean time has anyone experienced this or maybe has an educated guess? I realize the list of "could be" is long but hoping to get pointed in the right direction.
onesickpantera is offline
Old 08-11-2014 | 05:04 PM
SB
Bearings.
SB is offline
Old 08-11-2014 | 05:39 PM
Originally Posted by SB
Bearings.
Scott, bearings will vibrate to the point of feeling it without an immediate loss of oil pressure? It vibrated for awhile before the oil pressure dropped.
Old 08-11-2014 | 05:42 PM
SB
Broken piston(s) or crank and then bearings ? Or yeh, just some bearings.
I was tring to be short and sweet.
Motor is going to have to be taken out and inspected anyway...so I couldn't go wrong by saying bearings.
:wink:
SB is offline
Old 08-11-2014 | 05:47 PM
Outer ballancer slipped?
JRider is offline
Old 08-11-2014 | 05:50 PM
It does not explain loss of oil pressure
JRider is offline
Old 08-11-2014 | 06:14 PM
SB
A piece of a Jelly Donut got stuck to a piston and then fell off and is now clogging the oil pump screen.
That's my guess and I'm sticking to it.
SB is offline
JRider, what do you mean outer balancer? I was thinking something happened to the coupler or harmonic balancer/damper causing the vibration. Then the vibration wiped the bearings.
Old 08-11-2014 | 06:17 PM
Lol. I guess at this point it doesn't matter. But I would like to know what possibly caused it and what to look for.
Old 08-11-2014 | 06:19 PM
SB
Or shook off the oil pump pick-up.
There are many, many different scenarios like you mentioned in the first post.
Impossible to guess. We'll sit and watch to see what you find out.
SB is offline
