torque # 496 aluminum riser nuts?
12 ft lbs or 16 Nm.
more info
Exhaust Manifold to cylinder head 26 ft lbs
Exhaust elbow studs to exhaust manifold 15 ft lbs.
Next it always wise to torque in a 3 pass & proper torque pattern with everything.
In your other thread can you post pics of your problem area and what you done to hopefully fix your problem. I am just asking so I can be on the same page as to what you posted.
more info
Thank you. The only thing I removed were the riser nuts and riser. I figured it was less than 20, I was guessing 15. My boat is at the lake on the lift. I can take some pics this weekend. I haven't done any thing yet. I ordered the riser gaskets and silicone hoses. Hopefully they will be in by Friday so I can get back on the water Saturday.
