O2 guage
Old 08-13-2014 | 09:09 PM
Tinkerer's Avatar
Default O2 guage
I installed an INNOVATE O2 gauge two weeks ago. I went out boating last Sunday and the gauge never went off of 8 AFR.
I am getting a light sooting on the back of the boat. If I am getting sooting is that lower than an 8 AFR?
The sensor is good because tonight I connected my laptop to the control and it reads 20.9 O2 without the engine running.
Tinkerer is offline
Old 08-13-2014 | 09:41 PM
If you are running a true 8afr that is pig fat? The guage should move quite a bit from idle usually in the 13 or 14 range to 11.5 to 12 range at wot some like it richer or leaner.
27roadster is offline
Old 08-13-2014 | 10:07 PM
Tinkerer's Avatar
The gauge NEVER moves off of 8 after initiation when You turn the key. ( the gauge goes full scale and then to 8 on initial turn of the key.)
I am going to take the laptop with me next time out. That way I can see what the O2 reading is.
Tinkerer is offline
Old 08-14-2014 | 05:00 AM
It should be 22.4 with the engine not running.
Black Baja is offline
Old 08-14-2014 | 08:07 AM
The o2 sensors I`m familiar with do not read richer than 9.0AFR.
Your plugs would be pretty black. If it does not more off 8 something is wrong with the gauge/o2
ICDEDPPL is offline
Old 08-14-2014 | 08:35 AM
innovate will be 20.9 in free air
sutphen 30 is offline
Old 08-14-2014 | 08:36 AM
also never calibrate in the exhaust pipe but in open air.
Old 08-14-2014 | 12:20 PM
sounds like you are either pig rich or gauge/sensor is acting up. Have you pulled a plug, because at 8.0 it should look real nasty.
racinfast002 is offline
Old 08-14-2014 | 01:02 PM
Is the fuel mileage really crappy?
At 8:1 AFR, you should damn near be able to watch the gas gauge move...
Im thinking your sensor is dead.
TooLateVTEC is offline
Old 08-14-2014 | 02:47 PM
I concur with most above. The sensor is not calibrated or is bad. MUST do free air calibration. I actually don't believe your engine would physically operate with an AFR of 8:1. I've seen the high tens on initial tuning and the fumes were eye watering plus the engine idled like a nasty top fuel motor. The IAC surged like crazy trying to keep up.
Trash is offline
