500efi overheating hot port header, help >
Old 08-17-2014 | 08:08 PM
Default 500efi overheating hot port header, help
my port header on the port engine has diminished water flow and is hot to the touch. there is noticable difference of water exiting muffler compared to the other 3. the sea strainer also shows less water than starboard engine. the boat runs fine at cruise, 3200 rpm. if i run faster the motor will start getting hot and eventually alarm will sound.
my sea strainers are clean, new impeller and housing, new thermostat. what could be causing the diminished flow on the one header and causing engine to overheat??
engines have 500 hours of saltwater use, flushed every weekend after use, never rebuilt or opened up. headers been replaced 3 seasons ago
370ss500efi is offline
Old 08-17-2014 | 09:05 PM
32hustlin's Avatar
Registered User
Pieces of your last impeller. Sounds like you need to start cleaning out water lines
32hustlin is offline
Old 08-17-2014 | 09:24 PM
Or you have hoses collapsing under pressure
Jupiter Sunsation is offline
Old 08-17-2014 | 10:02 PM
last impeller was fine not in pieces, plus sea strainer is plumbed after sea pump so no pieces should go past. i do not think it is a hose collapsing under pressure since at idle at dock port muffler has diminished flow
Old 08-18-2014 | 01:56 AM
Inlet water neck from the Bravo drive is most likely full of corrosion.
Griff is offline
Old 08-18-2014 | 08:38 AM
how do you recommend cleaning the water neck from the bravo drive? It is a bravo 3 BTW. Do the drives have to come off?
