stupid question about electrical ... >
Old 08-19-2014 | 09:35 PM
Angry stupid question about electrical ...
So I've been having some wiring problems or rather gauge problems that have led me to start checking some wiring on my sea ray pachanga and for the life of me I cannot fine any fuses on thos boat anywhere. I feel like I've looked behind every removable panel. Maybe not I'm not sure all the switches seem to be a breaker style switch so did sea ray use these instead of a switch with a fuse on it? I'm sorry for my ignorance wiring is really not my thing hah
slowmo32 is offline
Old 08-19-2014 | 10:36 PM
My Fountain has no fuses, just various types of breakers. The dash panel is all switched breakers.
Cole2534 is offline
Old 08-19-2014 | 10:46 PM
Ok so then those just probably run off a...relay breaker in the engine compartment some where probably? I guess I figured they would have fuses also.
slowmo32 is offline
Old 08-20-2014 | 06:59 AM
Can you post picture of dash, all loads will be fused, or should be at some point. Follow the large + wire from battery headed to dash, at some point it will break off to all the little wires. Or it could be like my old wellcraft where they took one wire from battery, to inline fuse box, then the same wire went from breaker to breaker that was directly under each switch with a jumper from breaker to switch.
looseconnection is offline
Old 08-20-2014 | 07:00 AM
No relay no fuses. Just breakers on the dash.
1BIGJIM is offline
Old 08-20-2014 | 07:17 AM
You may or may not know this...
A breaker is a resettable fuse. The overload trips the breaker. If your able to reset the breaker the short is not present at that time. I don't think I have ever seen a fuse on a boat that wasn't put in after it was built.
Hope it helps
COOPS is offline
Old 08-20-2014 | 07:25 AM
F-2 Speedy's Avatar
32, what is the problem you are having
F-2 Speedy is offline
Old 08-20-2014 | 08:22 AM
Well I've been having some issues with gauges to start with the fuel gauge for example. It always reads 1/16th of a tank so I was told if I go to the sending unit and touch both wires together it should read full? So I tried that and it dropped to below E...so I reattached the the wires and still nothing the gauge sits below E kinda like I shorted something out or blew a fuse I guess I figured? Idk but I've got some problems with other gauges and light's and so I clean the connections and nothing happens so I guess I just assumed I shorted something somewhere. Sorry electrical is really not my thing
slowmo32 is offline
Old 08-20-2014 | 08:56 AM
F-2 Speedy's Avatar
I dont know anything about your boat, but I think the advice should of been, ground the gauge wire at the tank to test, not short anything together, sure sounds like no power issue, good luck
Old 08-20-2014 | 11:14 AM
I'm having a fuel gauge issue on my boat too. I gotta await clear weather to diagnose it. I think mine is ground related.
Jonesyfxr is offline
