Gen 6 Mechanical Fuel pumps to support 700hp carb?
Like the title says, I am looking for am looking for a gen VI sea pump mount type fuel pump that will support 700hp carb motor and not break the bank. I do not the the stocker is up to the task.
found these:
http://www.cvproducts.com/ProdDet.aspx?PN=SPIN-MP-2630
http://www.cpperformance.com/p-12460...6-engines.aspx
found these:
http://www.bakerengineeringinc.com/P...oCamParts.aspx
I found this, teague sells it also. Just wondering if the arm will work with the gen 6 sea pump cam? I dont really need the bling or the price.
http://api.viglink.com/api/click?for...oCamParts.aspx
It wont work the arm is to long, the cp is the only one out there. Just make sure you get a new lower part of the pump as I learned the hard way when we went to put it on we found out the seal was bad. If I new that I could of got both pieces together and is was cheaper, than separate.
