solenoid or trim pump bad? >
Old 08-26-2014 | 06:53 PM
ben
Default solenoid or trim pump bad?
On a 29ft fountain, drive won't go up or down but it makes a click when you hit the button either way. Would that be the trim pump, solenoid, or switch? Thanks!
ben is offline
Old 08-26-2014 | 06:58 PM
ROB FREEMAN's Avatar
bypass the selonoid n see
ROB FREEMAN is offline
Old 08-26-2014 | 08:12 PM
I would make sure batteries are good and then jump the solenoid. I found a dead battery last run when I went to trim the motors up to pull out front the house.
Solenoid are cheap and easy to replace....well, on a single engine boat!
nailit is offline
