Trim and Tilt Pumps, why is one so much faster?? >
Old 08-27-2014 | 03:48 PM
Default Trim and Tilt Pumps, why is one so much faster??
I am unable to properly trim my boat while running at speed as one trim pump is so so so much faster than the other. Both are connected to the same switch on the throttle but when you trim one comes up so much faster than the other that the boat starts to lean over very hard to one side. Making it feel to me to be very unsafe.
The boat also has separate switches on the dash for each drive. Using these you get the same result. It is no big deal if just trimming while on a long ride as you can take the time to even them out. But, if you want a quick burst of WOT forget it. Sticks to the dash and hit the trim button the boat feels like it is going to roll over as one drive comes up probably 10X faster than the other.
else ever run into this? Help, suggestions, insight in this matter is greatly appreciated!!
Baja226sport is offline
Old 08-27-2014 | 03:54 PM
Is it possible you have one 12V pump and one 24V pump. I do think Mecury has both flavors. I know you use the swap shop a lot so it may be possible. Good luck.
sonicss42 is offline
Old 08-27-2014 | 04:03 PM
Both pumps are original to the boat.
Old 08-27-2014 | 05:01 PM
I believe from a thread earlier this year that you can adjust the speed of each pump, slow one down and speed the other up. Also could be a poor connection.
buck35 is offline
Old 08-27-2014 | 05:45 PM
Make sure the fluids are the same viscosity first. One could be an outboard pump or a trim tab pump...I believe they have different orifices
JRider is offline
Old 08-27-2014 | 08:27 PM
your problem is not uncommon.the pumps have internal valving and as they get old they slow down due to internal leakage.it cost more to buy the parts to repair a pump than bying a new one.check out doug russel,s web site as he has great deals on new pumps.before you buy new make sure the ground is good on the slower pump.each one has it,s own ground wire.
mike tkach is offline
Old 08-27-2014 | 09:14 PM
VoodooRob's Avatar
Try flushing out the old oil in both and refill. Along the line someone might have added something different to one side.
VoodooRob is offline
Old 08-28-2014 | 07:01 AM
Have you tried switching them - that will let you determine if it is the pump itself or another issue (wiring, rams, etc.). If it is the pump I have a spare here you can use to get you through the end of the season (take out from the 280 I parted) and it looks relatively new.
Port Monster is offline
Old 08-28-2014 | 09:38 AM
Port Monster...I'm having the exact same porblem as Baja226sport, only with my trim tab pumps. IF and only IF Baja226sport can't use you pump I may be a buyer if you think it's in good condition. However, I'm not sure if Trim/Tilt pumps are the same as Trim Tab pumps. Do you know?
TIA, Jim
Thunderstruck27 is offline
Old 09-02-2014 | 09:14 AM
I might take you up on that. I will email you. Thanks!
