2000 37 in classifieds
http://www.offshoreonly.com/classifi...o58648-en.html
Surprised a thread hasn't been started yet, what's the story on this one? The cabin looks rough, all the carpet is ripped out, did it go under water?? Is it non stepped? Can't really tell from the pics.
Definately a straight bottom. The numbers don't add up unless you have a set of engines already. No hyd steering either.
It needs better and more pics.
The only all white 37 I remember is one that was for sale a long time ago. Rumor was that it had been repaired after a small engine fire when it was pretty new.
No sure if this is the same boat though.
Would this not be the perfect platform for a triple or quad OB install? Don't have to worry about screwing up the center of gravity on the step, install a 2nd row of bolsters and then move the bench back a couple feet into the bilge! With triple 300's the boat should run just as fast (or maybe faster) as it did with the 502's that it came with 14 years ago!
