High Oill Pressure? >
High Oill Pressure?
High Oill Pressure?
Old 08-27-2002 | 07:53 AM
Rich36PC
Question High Oill Pressure?
Can anyone suggest what action ( if any ) I should take based on the following observations:
1. My port engine (stock Merc 454) under normal conditions shows an oil pressure reading on dashboard guage around 38.
2. After running for an hour or so at around 3800 rpm I come back in to dock and at idle (approx 700 rpm) the port oil pressure guage is going high off the scale 90+
3. If I (gently) rev up the engine in neutral, oil pressure falls.
Since the starboard engine is not showing this behaviour I assume that something is wrong.
Rich S.
Old 08-27-2002 | 04:34 PM
mopower's Avatar
Toxic FORMULA
Rich , This is kind of a stab in the dark , but try changing your oil filter. Next I'd try the sending unit. If you don't want to waste the money , just swap with the other engine and see if trouble follows the sender. I have a similar problem. Both engines will be 45-50 lbs at 3500rpm and the starboard one will begin jumping around from 50 to 80 (never goes any lower). Its jumping too fast to be a pressure problem , more likely the sender. Leave them come back to an idle and they both settle on 35-38 and steady.
Good luck
mopower is offline
Old 08-27-2002 | 10:29 PM
The first thing I'd do is put a local guage in the block and compare. If it reads normal it's most likely a sender problem.
DAVE
Dave F is offline
Old 08-28-2002 | 01:59 PM
Offshore Addiction
oil pressure should work oppsite,of course.....it might be a bad filter....kinda iffy.....did see this once,a customer installed an automotive sender in his boat,but didnt realize they accually work backwards......at 10 psi on a manuel guage the electric was at 90+....at 80 psi the electric was at 10-.......just a thought
Old 08-28-2002 | 03:52 PM
mopower's Avatar
Toxic FORMULA
Rich , Let us know what yo find , Inquiring minds want to know
mopower is offline
Old 08-28-2002 | 04:29 PM
Rich36PC
Thanks everybody for the suggestions. Another friend has suggested that I have a positive short. He says that if I tap the guage it ought to swing back down. He sounds very definite about this. It will be Saturday before I can get back to the boat. I will definitely post whatever I find out.
Rich S.
Old 08-28-2002 | 06:16 PM
BLOWN 1100's Avatar
I think your friend is right, sounds like a ground
problem to me.
BLOWN 1100 is offline
Ran-Dom 32
34
11-27-2008 10:57 PM
BDiggity
7
07-07-2008 05:57 PM
chip12345
19
05-22-2005 05:25 AM
Jrock
11
05-25-2003 01:57 PM
GNJ2
4
12-26-2002 08:00 AM
