Ram air
Old 09-01-2014 | 09:40 PM
Tinkerer's Avatar
Default Ram air
How many of you with hood scoops have them sealed to the carb to get the most of the ram air effect. I am finding that I get a lot more RPM with the ram air. I am going to seal the scoop to my carb because at about 90 the air pressure in the engine compartment blows the cushions off of the rear bench seat - when this happens I lose about 200 RPM and the fuel/air mixture gets real messed up.
Spent some time dialing in the carb this weekend. It is close but there are still a few lean spots.
Tinkerer is offline
Old 09-02-2014 | 04:59 PM
anytime you can give the engine cooler air to take in going to run better...I always run the blower whenever engine running, have 1 drawing air out and 1 bringing in cooler air...race cars always seal the carb to scoop and yes sometimes will lean them out if they are on the edge..
ezstriper is offline
Old 09-02-2014 | 09:11 PM
would it make a difference to put a ram air setup on a efi system? With a air box and tube set up.
1989mach1 is offline
Old 09-02-2014 | 09:34 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
the deep is offline
Old 09-02-2014 | 09:46 PM
Tinkerer's Avatar
Anytime you can get more air into the engine you will create more HP. The problem with EFI that doesn't use an O2 sensor is it won't know that it is now running lean.
Tinkerer is offline
Old 09-02-2014 | 09:54 PM
My only concern would be what that the ram air stream be smooth without turbulence, which might cause erratic MAP sensor readings and thus performance.
Trash is offline
Old 09-02-2014 | 09:55 PM
The engine at WOT is drawing more air through than the blower so operating it at this point would be a moot point.
Trash is offline
Old 09-03-2014 | 01:48 AM
Im wondering whats gonna happen when you hit a bad wave and some of it comes over the scoop and sucked right into the engine..
HTRDLNCN is offline
Old 09-03-2014 | 08:20 AM
Ram Air
ICDEDPPL is offline
Old 09-03-2014 | 08:29 AM
Its still moving more air in the engine room from outside, so some cooler air brought in is better than none...not like trying to draw the blower..
