502 EFI shutting down after 5 seconds of run time >
Old 09-03-2014 | 04:47 PM
whiskeyhangover's Avatar
Default 502 EFI shutting down after 5 seconds of run time
Motor will fire off and run for about 5 seconds or then
shut down.
I've checked the fuel pressure and it's pretty constant around 30 psi and when motor shuts off the pressure jumps to about 37 psi. Also we've checked to make sure the coil was firing off as it should and that checked out ok.... any help or suggestions would be appreciated on what the problem could be.
thanks.
whiskeyhangover is offline
Old 09-03-2014 | 04:56 PM
Does it cut off clean or does it stumble and then cut off?
TooLateVTEC is offline
Old 09-03-2014 | 05:04 PM
Is it seeing oil pressure?
buck35 is offline
Old 09-03-2014 | 05:41 PM
Yes it cuts off clean and it does see oil pressure.
Old 09-03-2014 | 06:45 PM
shut down.
thanks.
What kind of EFI system do you have?
AllDodge is offline
Old 09-04-2014 | 06:13 AM
502 magnum mpi
Old 09-04-2014 | 07:02 AM
This at cold start, or after you've been running for awhile ? Sounds like vapor lock.
I think a little more background will get some better answers.
buck35 is offline
Old 09-04-2014 | 07:29 AM
Cold start up now.... the vapor lock issue has been fixed by returning fuel back to the tank. The starboard side motor runs fine though.
Old 09-04-2014 | 08:00 AM
502 magnum mpi
Don't know if you have cool fuel or VST. Could use a bit more info as to the engine setup and what it was doing before this issue. First thing is I'm thinking it may be the IAC. Can you give it a bit of throttle and see if it will continue to run?
AllDodge is offline
Old 09-04-2014 | 09:00 AM
Vst..... you can give it throttle but dies right out. It literally runs for 5 sec. Everything was fine before and it ran great.
