Hydraulic Steering recommendation for 240 Sport + Shorty Lower Discussion >
Old 09-04-2014 | 07:53 AM
Default Hydraulic Steering recommendation for 240 Sport + Shorty Lower Discussion
1987 240 Sport. Has a built 505ci, roughly 615hp. Boat currently runs mid 70's GPS but likes to walk of course. Would like to do my best to get the boat as stable as possible to be able to better enjoy the upper 60's and lower 70's speed. Previous owner suggest to look into something like a 2" shorty lower and for sure some hydraulic steering. Who makes a good, easy to install set-up that you would recommend?
Also I did some research on the shorty lowers and found boats react differently to them of course and not much info on the 240 sport with one. I believe the one I found the guy liked what the 2" lower did for him... anyone else running one and what may you recommend?
Hydraulic steering will be the first upgrade.
Thanks!
Superman09 is offline
Old 09-04-2014 | 07:57 AM
Thanks!
I have a 24 ft outlaw with a super charged 502 and it runs 80 mph top speed. I put full hydraulic steering from imco on it and runs great at high speeds. I would recommend imco steering unit.
jj
conneroutlaw is offline
Old 09-04-2014 | 08:03 AM
jj
Great thank you!
Old 09-04-2014 | 08:05 AM
Great thank you!
I had the same problem, I am glad I could help
jj
Old 09-04-2014 | 08:08 AM
jj
Do you have a part number or a link to the set-up you purchased? I find Imco's site very difficult to use
Old 09-04-2014 | 10:06 AM
X2 on the imco kit, mine loves the shorty.
http://www.imcomarine.com/nvcatalog/imco_catalog.pdf
[IMG][/IMG]
[IMG][/IMG]
baditude is offline
Old 09-04-2014 | 10:42 AM
I called imco in las vegas and the guy was very helpful on the phone. I have no part number, Not much in the box except instructions. Call them and they will ask you a bunch of questions about your set up and guide you through to getting the right one. I liked imco because of how it is made and the ability to rebuild it if needed. I did some research on them and lathem and I liked imco better
Old 09-04-2014 | 10:53 AM
phone number in las vegas 1-888-427-7436
Old 09-04-2014 | 11:26 AM
I also have been thinking about this for quite some time.
All of my slop/friction in the steering system is inside the boat. By that I mean the helm and cable. Is there any hydraulic system that replaces these items and connects to the standard inside control (Brazil) valve on the transom? At a later date the external system could then be added. I would find this a much better way to go about it than doing the external system first.
Dan
BajaDan is offline
Old 09-04-2014 | 12:09 PM
[IMG][/IMG]
[IMG][/IMG]
Thanks, looks awesome! Was that all one kit with the shorty and the steering? If so which one in their catalogue?
