502 magnum mpi IAC crossover
My IAC is intermittently working. Nothing open this weekend that would have one does anyone know of the OAC crosses over to an automotive that I might be able to find at Oreillys? Thanks.
Unfortunately that one doesn't look like mine. Mine is this part number. Does anyone know if this crosses over? Thanks
805224A 1 - MOTOR KIT -IAC
Or a Sierra 18-7632.
Any automotive crossover??
Ahh, you have a 97 or older 502 mag. You need a NAPA Echlin # CRB 21755.
Common GM IAC from say, a 2000-2005 Chevy Impala with a 3.4 liter if you need to give your parts house a year make and model.
Good luck
Good luck
Changes the iac with a Sierra 18-7632.
Unfortunately, I turned the ignition switch to on when the iac was not hooked up, to try and test the voltage. The alarm started beeping twice every ten seconds or so. Will not stop
Replaced and started engine. Still surging. Placed my finger over iac hole, no difference.
Alam still sounding.
Any advice?
Any advice?
