500 efi sputtering under load
I am trying to get a boat sold for a buddy. Has been sitting for 2 years has a 500 EFI the boat is a 01 Sonic Prowler. We did plugs, distributor cap, fuel filter and pulled the injectors and them cleaned and flow tested. When we first fired the boat it was only running on 5 or 6 cylinders so we pulled the injectors and did the service. Ran the boat on the hose for about an hour everything seemed fine. I put 50 gallons of ethanol free premium in the boat, the was about 15 gallons of old fuel still in the tank. Splashed the boat today for a test drive. Idled out then took it easy out of the hole tabs down trim down and couldn't get it to plane out before it started missing. Tried 5-6 times but no go. It will go along for 20-30 seconds at 3500-4000 or so then start to die. Was backfiring and RPM's would die back to idle. I am thinking to replace the fuel pump any other suggestions would be greatly appreciated.
Greg
Greg
I,D check the fuel pressure before I spent the money on a new pump. Also you said you replaced the plugs, cap & rotor did you replace the plug wires as well if not test the wires as well. Check the coil and timing as well.
Greg
Greg
