Front Seal Unazzed >
Front Seal Unazzed
Front Seal Unazzed
Old 09-08-2014 | 10:48 AM
Default Front Seal Unazzed
Anybody ever seen a front seal push out of the timing chain cover for no apparent reason? The whole seal, metal and all.
payuppsucker is offline
Old 09-08-2014 | 10:59 AM
A little too much blowby?
MILD THUNDER is offline
Old 09-08-2014 | 11:04 AM
They're brand new motors, 540's. About 75 hours, breathers in both valve cover. However, on a couple of occasions each of them have pushed the dipsticks out about a half inch.
Old 09-08-2014 | 11:06 AM
Doesn't use any oil or drip from the breather.
Old 09-08-2014 | 12:21 PM
i agree with mild,to much crankcase pressure can cause that.
mike tkach is offline
Old 09-08-2014 | 12:45 PM
Long story short. Rebuilt one motor put new valve cover breathers on both, two per motor. After long hard runs old motor lost oil out of rear main seal. Pulled old motor replaced seal, oil leak not so bad now and both dipsticks are up two inches. WTF!! Took the foam out of the new breathers and that fixed my problem.Good luck and be safe.
30ftpanther is offline
Old 09-08-2014 | 12:47 PM
donzi matt's Avatar
Are these motors boosted or naturally aspirated?
donzi matt is offline
Old 09-08-2014 | 12:53 PM
There is hardly any blow by at the valve covers. Are you talking pressure just from the displacement of the pistons? Why the hell would it push out a driven in seal before it could pop a valve cover breather out of its grommet, which on my motors just happen to fit loosely?
Old 09-08-2014 | 12:54 PM
NA Matt.
Old 09-08-2014 | 12:57 PM
Since you mentioned this the dipsticks have only been pushed out when the breathers have a few hours on them since being rinsed with Avgas.
