tall deck to short deck exhaust problems >
Old 09-09-2014 | 12:18 PM
bck's Avatar
bck
Charter Member#568
Default tall deck to short deck exhaust problems
So I went from tall decks to short decks thinking that slight difference wouldn't have much impact on the exhaust. Wrong. None of the CMI big tube tails fit anymore. Has anyone ever made an adapter plate to move the headers back closer to the tall deck position? Would it be possible? Any help/ suggestions would be great. I've talked to CMI and they aren't a whole lot of help.
Straight bottoms and flat decks
bck is offline
Old 09-09-2014 | 12:39 PM
Tips on the transom or dry tails that go through?
Unlimited jd is offline
Old 09-09-2014 | 01:09 PM
bck's Avatar
bck
Charter Member#568
Dry tails through and to make things worse it's staggered, so I've got issues where the front motors tail won't fit past the rear motors header now.
bck is offline
Old 09-09-2014 | 02:26 PM
I would think that you will have to have new tails made or possibly put on some heads with raised exhaust ports to make them work. Someone good with a mill could probably make you some adapters. but I bet they wouldn't be cheap or pretty.
snapmorgan is offline
Old 09-09-2014 | 02:57 PM
bck's Avatar
bck
Charter Member#568
These are the old style big tubes, so they already have adapter plates. I was thinking a wedge type adapter to tilt the headers outward a little bit? Does anyone have a blueprint that would show the exact difference between a tall/short deck at the exhaust port?
bck is offline
Old 09-09-2014 | 03:35 PM
Its 5/8 down & 5/8 in going from tall deck 10.2 to short deck 9.8. depending on the style of heads. If you have the old wrope seal headers its a easy fix. With the flex flair you can get adapter rings that CMI makes. If you wanna call me I can explane in more detail & send you in the right direction 920-475-0852
Bawana is offline
Old 09-09-2014 | 04:07 PM
runninragged's Avatar
cmi can mill exhaust flanges to use as a shim to angle the header in or out dont know if thats going to help though
runninragged is offline
Old 09-09-2014 | 04:54 PM
bck's Avatar
bck
Charter Member#568
Bawana, is that a good number to send some pics to? I'll send a few showing what I'm working with then give you a call. I'm using AFR 315 heads on a 9.8, the previous heads were Brodix big brodies on a 10.2
bck is offline
Old 09-10-2014 | 02:00 AM
yes text me pics & then call me
Bawana is offline
