Prop shaft carrier bearing stuck >
Old 09-12-2014 | 02:27 PM
Scarab28's Avatar
Default Prop shaft carrier bearing stuck
Any tips out there - trying to remove Imco prop shaft carrier bearing. Shaft has a slight twist on it. Hooked puller up to it but
it won't budge. Heat? Help
Scarab28 is offline
Old 09-12-2014 | 02:35 PM
I pressed mine.
Eliminatorshane is offline
Old 09-12-2014 | 02:54 PM
Use a bravo input spanner wrench as a spacer behind the prop then tighten the the prop nut. Pulls the shaft and carrier out.
Unlimited jd is offline
Old 09-12-2014 | 03:20 PM
Scarab28's Avatar
Good idea - will give it a try.
Scarab28 is offline
Old 09-12-2014 | 03:43 PM
Scarab28's Avatar
Yeah L Red - that worked like a champ! Great tip, would have never thought of that one.
Scarab28 is offline
