Who's got an axel
Old 09-13-2014 | 02:14 PM
Default Who's got an axel
Firstload axel pulled the nut off any help finding an axel would be great 2004
mcprodesign is offline
Old 09-13-2014 | 09:17 PM
does not look that bad,,try rethreading the axke end and a new nut,,the nuts are a softer thread so the nut takes the bulk of the dammage..if that dont cut it you can replace the end,in my area theirs a guy called the axle saver,,200 bux installed..
FIXX is offline
Old 09-14-2014 | 11:58 PM
Yeah the nut is supposed to be softer but it tore all the threads off. And the hub took A bit more off the bottom than that when the wheel tried to come off. Go thing i check my mirrors a lot that's all I can say. No more u turns either!! I can weld some stuff on there and grind it and get a die and re cut the threads. That's what I think I'm gonna do/ If that doesn't work I could get it sung and weld the friggin nut on it. Axxel is junk anyway. Put new bearing on it. I wanna try to weld an re thread it first. Boat is going no where til I do this!
Old 09-15-2014 | 07:32 PM
did not know toy can weld lol...well if you have a plasma cutter or a TC arc torch to blow the welds on the old one you can try replacing just the end.. http://www.etrailer.com/Trailer-Spin.../R50342EZ.html
FIXX is offline
Old 09-15-2014 | 07:40 PM
SB
Who's got an Axel ?
I do. He's on my lap wanting some of my hamburger. Dam dog. lol.
SB is online now
Old 09-15-2014 | 11:44 PM
did not know toy can weld lol...well if you have a plasma cutter or a TC arc torch to blow the weldsu on the old one you can try replacing just the end.. http://www.etrailer.com/Trailer-Spin.../R50342EZ.html
i can't see how an axel can be only 66 bucks. That is amazing. But probably cheap alloy. but that is ok because i probably have cheap alloy on the other 5 anyway. Lol. And yes i got a plazma cutter. Thanks for the help !!
Old 09-16-2014 | 12:59 AM
yea,,this one i posted is for a 5200 lb axle so i was not sure what your's was..their are more options if you click or type in spindle's..
FIXX is offline
