restrictors in 600 headers >
Old 09-14-2014 | 01:52 PM
crayolacrazy's Avatar
Default restrictors in 600 headers
does any one know the whole size in the water flow restrictors , on 600 efi 525 s they are made to hold back water to fill header
crayolacrazy is offline
Old 09-14-2014 | 03:42 PM
starboard is .389, port is .406
HyFive578 is offline
Old 09-14-2014 | 08:28 PM
slightly different thank you
Old 09-14-2014 | 09:07 PM
SB
525 : shows .406" for both sides
http://www.mercruiserparts.com/Show_...lpipe+Assembly
600sci shows the same as above:
SB is offline
Old 09-14-2014 | 09:10 PM
The big question is whether to use them or not. I thought there was a Merc. service bulletin that called for them to be removed along with the bypass hoses tying the distribution rails to the tail pipes. On my 47 Fountain with triple 525's, my rear engines have the restrictors in the tails but my center engine does not. None of my headers have the bypass hoses.. sorry if this is a minor hijack but might benefit the OP too..
Old 09-14-2014 | 09:26 PM
SB
Hre's the bulletin:
http://www.offshoreonly.com/forums/a...der-update.pdf
That was From this thread:
http://www.offshoreonly.com/forums/g...ulletin-2.html
SB is offline
