big cubic inch chevy?s >
Old 09-26-2014 | 02:30 PM
bcfountain's Avatar
Registered User
Default big cubic inch chevy?s
what would be the best size motor for a marine applation?572,598,632.merlin or dart raised block,tall deck?how do they hold up and will they run awhile without a lot of manatince?not looking to get crazy.mild roller hyd,merlin grumpy jenkin 320 cast iron heads.wet sump oiling.850 carb.
bcfountain is offline
Old 09-26-2014 | 02:46 PM
I have a pair of 598 GM bowtie blocks built by Goodwin competition in WI. Hope to live a long time. 700+hp
drpete3 is offline
Old 09-26-2014 | 03:09 PM
GPM
Depends on what you're going to do with it. I'm guessing your heads will be the limiting factor, the bigger bore will breath better, the 4.75 crank may not be the best for rod to stroke angle.
GPM is offline
Old 09-26-2014 | 03:21 PM
Wobble's Avatar
SORE MEMBER
http://www.strokerengine.com/DartBBC.html
lots of options, short deck, I think I favor a 565.
this article is what sells me on that combo http://www.enginebuildermag.com/2012...ss-565-engine/
Wobble is offline
Old 09-26-2014 | 03:24 PM
If you are gonna go big, with a fresh block, rotating assembly, etc, why limit yourself to "Merlin 320" heads, and "850" carb.
Figure out how much power you want to make, then pick the parts to do it. Its hard to beat a nice 4.5" stroke tall deck setup.
MILD THUNDER is offline
Old 09-26-2014 | 04:23 PM
Thumbs up
I love the 200, 000 mile warranty on Merlins
Ive tried all the other models
Dopey
Sneezy
Sleepy
Bashful
Happy
but grumpy seems to work the best for me.I think you`re on the right track
ICDEDPPL is offline
Old 09-26-2014 | 05:14 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Of course they will! You only go out once every two years!
Sydwayz is offline
Old 09-26-2014 | 05:20 PM
How did you come up with a 4.75 crank?
benjen is offline
Old 09-26-2014 | 05:27 PM
Well, I know how you came up with the 4.75 for a 632, but he listed 2 other versions that can be done with a 4.50 or 4.625 I think.
benjen is offline
Old 09-26-2014 | 08:36 PM
GPM
4.56 x 4.375 or 4.5 x 4.5 for a 572, 4.6 x 4.5 for a 598, 4.6 x 4.625 for a 615, 4.6 x 4.75 for a 632 and on and on, just depends on what you want to spend and where you want to make the power.
GPM is offline
