525 merc refresh 350 hours >
Old 09-28-2014 | 07:43 AM
bblythe's Avatar
Default 525 merc refresh 350 hours
I have been told the heads will need to be gone though and the rockers should be updated The question I have brand and style of Rockers?
bblythe is offline
Old 09-28-2014 | 09:28 AM
VoodooRob's Avatar
Suggest lifters and pushrods also.
VoodooRob is offline
Old 09-28-2014 | 09:55 AM
donzi matt's Avatar
Lifters, pushrods, springs, AND rockers at 350 hours? How realistic is that? You are talking about 2-3000 dollars worth of maintenance every 350 hours, that seems nuts to me. I could see springs being a wear item at 350 hours but the rest of the valvetrain seems like it should be more stout than that. What are these things going for in the real world before failures are seen?
donzi matt is offline
Old 09-28-2014 | 10:22 AM
About 351 hours. lol
The 525 has a fairly agressive cam. Not radical by any means, but, its a far cry from a little 224/224 480 lift 502 mag cam. I am not sure what lifters merc used in them. Im sure by 350 hours, the rockers may show signs of fatigue (aluminum), valve seats needing a regrind, etc.
Might be nice time to get those edelbrock heads cleaned up a bit too. Like a little chamber porting to help low lift airflow, a good back cut on the valves if they arent already, and some cleanup in the bowl area, and a little milling to keep compression up after the chamber work.
Has anyone ever done anything like that during a 525 overhaul? The edelbrock heads are not known to flow all that great out of the box. I'd imagine with a little work, maybe pick up 25-40hp?
MILD THUNDER is offline
Old 09-28-2014 | 10:37 AM
Depends how you drive it. Under 3000 rpms most and it will last twice as long. Most are run hard i would guess.
Pismo10 is offline
Old 09-28-2014 | 11:13 AM
what about replacing the edelbrock heads with the Darts?
Pwraddr is offline
Old 09-28-2014 | 11:36 AM
bblythe's Avatar
I really just want to fresh them up but i have read the rocker merc is using are junk so i have read T&D and crower work well . Which ones or is this bad info. I really dont want to reflash ecm unless I really going to spend some loot,
bblythe is offline
Old 09-28-2014 | 12:03 PM
I plan to have my heads gone through with new springs and valve job and inspect the rockers.
thirdchildhood is offline
Old 09-28-2014 | 04:26 PM
VoodooRob's Avatar
I did complete valve job replacing everything but valves. Also replaced lifters, and pushrods all work at 380 hrs. Rockers were all inspected and passed. On OSO many valve spring failures in these engines, lifters falling apart too. Anyone running past 350hrs on these engine are on borrowed time. Maintenance is what it is, these engine are just BBCs running 5,000 rpm in a constant water hole. Something is going to break at some point. I wish it was only $2-$3k in parts!
Old 09-28-2014 | 05:29 PM
bblythe's Avatar
I have been quoted about 8 grand a motor to pulled freshed up installed .This seem about right
bblythe is offline
