Exhaust manifold differences 502 vs 525 efi >
Old 10-01-2014 | 07:43 PM
Default Exhaust manifold differences 502 vs 525 efi
How do the factory exhaust manifolds differ from one another on the 502 mpi and the 525 efi engines? Can they be interchanged?
Superman09 is offline
Old 10-01-2014 | 07:48 PM
No. The 525 comes with headers on a different bolt pattern. 502 mpi is reg manifolds on standard bbc bolt pattern
Crude Intentions is offline
Old 10-01-2014 | 07:49 PM
F-2 Speedy's Avatar
NO, the 525 has Edelbrock alum heads and a non standard exhaust bolt pattern, the 502 has a standard BBC bolt pattern
haha typing at the same time
F-2 Speedy is offline
Old 10-02-2014 | 08:19 AM
Thanks guys. I am building a manifold set-up and was hoping I could cater it to both engines, but I will have to do 2 I suppose! Are they both the same angle heads? Could I simply swap the cylinder head flange to make it work on both?
Old 10-02-2014 | 08:32 AM
F-2 Speedy's Avatar
Are you building headers, dont really understand the Q
Old 10-02-2014 | 08:41 AM
Somewhat, yes. I was wondering if I build them based on the 502 if they could also be used on a 525 efi. Now that I know they are different, would a flange swap be all that is required to make that happen?
Old 10-02-2014 | 08:44 AM
F-2 Speedy's Avatar
yep, if you change the flange to match the 525 bolt pattern
Old 10-02-2014 | 08:50 AM
Easy enough! Thanks!!
Old 10-02-2014 | 09:11 AM
F-2 Speedy's Avatar
just a side note, the bottom 4 holes will line up, its the upper four that wont, beleive me I know, I redrilled my CMI GenX to fit my AFR heads,
Old 10-02-2014 | 09:17 AM
I'll have to get a pair of each in hand to check them out. I wonder if the flange was drilled for BOTH if any issues would result or if this would allow them to work on both!?
