Winterizing sterndrive/engine pink or green antifreeze
Everyone seems to reference pink anti freeze RV but why not use ethylene glycol for cooling systems.I have personally seen pink turn to slush but slush is not ice.Is ethylene glycol ok?Automotive cooling system coolant has corrosion inhibitors that would be beneficial I would think.
Always had Alpha drive boats that more or less self drain with the engine being the exception.
Back in the day I used the green antifreeze - In fact I drained it out and re-used it. Of course after a few years I had to replace a little. With the dawn of the RV Pink stuff I have used that for the past 10 years - and won't go back -- You don't need to worry about hurting the little fishes or if you drain in the drive and Fido licks some up you don't have to worry about poisoning the dog. If my block didn't freeze and break last year with the pink stuff -- it never will.
3pointstar
3pointstar
the automotive green or orange is very toxic and bad news dumping onto the ground or waterway,if you drained into a bucket you could reuse,we use pink -100 and mix a little water into never a problem do around 200 motors every year in the spring just start the engine and dump it,thats why they call it non-toxic
