Go Back  Offshoreonly.com > Owners Forum > Powerquest
Play in steering wheel >
Old 10-02-2014 | 08:47 PM
Default Play in steering wheel
I have a 2003 260 Legend with 496HO and noticed a bit of free play just rotating it left and right just a bit. Have noticed on occasions it will pull left not all the time but sometimes and when it does it will pull a little then other times it will pull quite noticeably. Would this be a Gimbal bearing issue? Thanks for any feed back.
pq260ho496 is offline
Old 10-03-2014 | 04:54 AM
Is there any side to side play at the drive? The drive should be tight with virtually no play side to side.
Questofpower is offline
Old 10-03-2014 | 08:35 AM
Sounds like a worn gimbal ring and upper swivel pin.
Cory H is offline
Old 10-03-2014 | 10:07 AM
+1 on that.
payuppsucker is offline
Old 10-03-2014 | 10:45 AM
you might have some side to side play with engine off,run it on the hose and check it,with the engine running the p/s pump built pressure In the rack and takes some of the side to side play away,if still loose then check the torque on the u bolt nuts,should be 53lbs
boatnt is offline
