Mercruiser, the big round harness plug.. >
Old 08-28-2002 | 09:42 PM
DanL
Default Mercruiser, the big round harness plug..
Went to plug the big round harness into the newly wired Merc engine harness, problem is my 1988 boats harness is off by the addition of another larger pin. Nine pins in total, 3 larger than the rest. The new Merc engine harness will accept only 2 larger pins. The odd pin looks like an 8 gauge red coming from the fuse panel. did Merc change the harnesses?
Old 08-28-2002 | 09:59 PM
KAAMA's Avatar
Welcome to the club Dan! Seems like everything I do to get my engines set in my boat I run into all these little problems something like what you are experiencing with your wiring harness.
KAAMA is offline
Old 08-28-2002 | 10:11 PM
Audiofn's Avatar
Charter Member #232
Oh crap I hope that does not happen to me tomarrow!!!!
Put your best foot forward!
Audiofn is offline
Old 08-29-2002 | 04:59 AM
David's Avatar
The plugs have come in 3 variations that I am aware of, but there may be more. 8 pins, and 2 with 9 pins. One is numbered 1 thru 9, the other numbered 1 thru 8 and a #10 pin (#9 missing)
David is offline
Old 08-29-2002 | 06:43 AM
Mbam's Avatar
Offshoreonly Advertiser
Dan, to anwer your question yes the harness has changed. The 88 harness uses an ammeter so there is a feed and return to the dash that completes the circut from the alternator to the battery. The new engines use a voiltmeter, much better set up.
Mbam is offline
Old 08-29-2002 | 07:37 AM
DanL
thanks. I'm hard wired on both sides. The engine harness was 6 hours of cut,solder,heat shrink of 2 full MSD's, times 2 for the engines. Engine plug is 9 pins. Is it just the extra larger pin thats different? I'm assuming I'll need 3 schematics to compare.
Old 08-29-2002 | 07:39 AM
GregP's Avatar
When we pulled/installed the motors in my boat several of the pins in the Merc plug were loose and a couple came out. Merc wants a ton for them, plus they no longer had the early version that my boat used.
Rather than re-wire everything from the panels back with new Merc plugs (harness wires are not removabel) I just bought some mil style round connectors (which have replacable pins in case there is ever a problem in the future) and replaced both ends. All it takes is a little time crimping the new pins onto the wires and then installing them into the connector bodies. The new plugs include heat shrink back shells for wire strain relief and gaskets to keep them water tight.
-Greg
GregP is offline
Old 08-30-2002 | 07:13 AM
DanL
well, found out there is an extra pin,so, break it off and the harness plugs in. Except the pin was the feed to the fuse block under the dash. Can these plugs be rebuilt or replaced? The pins are knarly enough to be crimped and pushed back throough. I'll be usung a but connector and heat shrink to get it fired on the hose but need a permanent fix. Thanks
Old 08-30-2002 | 07:25 AM
Audiofn's Avatar
Charter Member #232
Can you just run a jumper wire up to the dash for now? I am curious as I am going through the same problem. HOWEVER my ignition does not get its power from the harness so maybe I can do the same thing? I will look into it. I will definatly change over the wire like Next week but man to have to rewire the dash with the new harness will suck!!!! I was looking at it yesterday and thinking that MAN this is so close to going in.
Jon
Audiofn is offline
Old 08-30-2002 | 07:57 AM
GregP's Avatar
Originally posted by DanL
... Can these plugs be rebuilt or replaced? ...
Nope, that's why I went with "servicible" aftermarket plugs. Was able to mount it in the same bracket by just drilling a new bolt hole.
-Greg
GregP is offline
