Can I start the engines on the hose with the drives off? >
Old 10-09-2014 | 07:29 AM
Default Can I start the engines on the hose with the drives off?
525 EFI - XRs
Have flush ports so I dont need to use muffs. Can I start them on the hose with the drives off the boat?
Pwraddr is offline
Old 10-09-2014 | 07:34 AM
yep,,done it many times,
boatnt is offline
Old 10-09-2014 | 07:52 AM
Yes, just cover up the gimbal housing so you don't get water from the exhaust getting into the exposed areas.
HyFive578 is offline
Old 10-09-2014 | 02:11 PM
my flush port on a 502 mag runs in to a t that feeds the sea pump, can I fill with antifreeze through this port?
stimleck is offline
Old 10-09-2014 | 08:40 PM
Thanks guys!
Pwraddr is offline
Old 10-09-2014 | 09:51 PM
You should be able to. The suction from the sea pump should pull the antifreeze through. You should make sure your container of antifreeze is higher than the flush port to allow gravity to assist the feed to the sea pump..
Old 10-10-2014 | 05:38 AM
Vinny P's Avatar
I hate the winter!!
Yes you can. I would suggest taping up the intake ports on your drive with some duct tape. That way, the seapump will not suck any air.
Vinny P is offline
