Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
Hey GlassDave ? on repair of chips on lifting strakes >
Old 10-09-2014 | 02:04 PM
Default Hey GlassDave ? on repair of chips on lifting strakes
Hey GlassDave,
What would be your recommendation for repairing the chips on the lifting strakes - I've ground them down with a dremel tool to check the fiberglass behind them - they seem to be ok - now what? LOL! One is about the size of a dime and the other is about 3 inches long
Thanks!
MooresWarlock is offline
Old 10-09-2014 | 07:44 PM
Use a 3M vinyl ester based filler if you want to re-gelcoat them, or better, use an epoxy filler and re-paint. You will not be able to use gelcoat over an epoxy repair. Dave will chime in.
ren3 is offline
Old 10-10-2014 | 10:19 AM
Thanks for the quick response and info!!!
Old 10-10-2014 | 04:13 PM
glassdave's Avatar
Neno the mind boggler
I do like 3M's premium marine filler plus its good below the waterline. I also have a local supplier that has a snow white VE filler that really is some nice stuff and hard as f#&k when cured. its from Michigan Fiberglass and they do ship
http://www.michiganfiberglass.com/
cant remembered the number of it but it is their white styling filler.
08 OPA High Points Champion
glassdave is offline
Old 10-13-2014 | 11:40 AM
Thanks GlassDave and ren3! Picked up some 3M premium marine filler and spent all Sunday grinding - filling - sanding and it came out GREAT! Previous owner let boat drift onto some rocks and had some 20 little chips along the lifting strakes - should be able to start gel coat process tonight!!!
