Weight of Topgun with 6 drives >
Old 10-10-2014 | 06:03 AM
Default Weight of Topgun with 6 drives
A friend of mine is looking at a rigged topgun straight bottom hull no power with wet number sixes . Does anyone here know what a rigged topgun weights with six drives ? Thanks RG.
Rick G is offline
Old 10-10-2014 | 06:10 AM
F-2 Speedy's Avatar
Fully rigged ?? Im guessing 10,500, no fuel, no beer
F-2 Speedy is online now
Old 10-10-2014 | 07:37 AM
What is the hull material? Carbon, Kevlar, or glass? Outlaw is probably pretty close, but if it's a glass boat, I would say closer to 11k without fuel maybe even a touch over .
5's on Boxes is offline
Old 10-10-2014 | 08:04 AM
I have a 1994 Cigarette Top Gun flat bottom with a notched transom and the boat came with bravo 1 drives. I have Arneson drives now. The manual reads that DRY weight is 11,500lbs with the twin 600 hawk motors and bravo 1 drives. The boat holds 220 gallons which is 1320lbs. 6lbs per gallon. Total boat weight is 12820lbs without people, water in the tank, beer, anchors, ropes, finders, etc.
UrbanDisturbance is offline
Old 10-18-2014 | 05:21 AM
Zero Patience's Avatar
Mine weighs 14,400, with full fuel, dry sump 6a, blower motors. That is from a travel lift scale.
Zero Patience is offline
Old 10-18-2014 | 09:36 AM
Zero I believe it , I had a feeling they were heavier than 12 k pounds I think my Kevlar flat deck with 5 weights 12,000 pounds . Thanks for the info.
RG.
Rick G is offline
Old 10-18-2014 | 10:13 AM
Thats on the trailer pre fillup
ICDEDPPL is online now
Old 10-18-2014 | 12:52 PM
How crap Dan that's more than I thought. I am guessing full load of gear ? Mind you that would include the weight of the trailer . Still that's about 2,500 more pounds than I would have guessed. The sad part mine being a Kevlar hull I'm told its only good for about a 500 to 800 lb weight savings.
RG.
Rick G is offline
Old 10-18-2014 | 02:17 PM
I thought the Kevlar was at least 1200# lighter, they stick out of the water quite a bit more than a regular layup.
I had gear in there but a couple of bags of clothes and some pillows and blankets isn`t breaking the scale.
Id imagine boxes and #4 weight as much as a #6
With a wave killer come great responsibilty
People wonder why I think my 8.1l is weak .. well look at the job its tasked to do.
Old 10-19-2014 | 09:55 AM
11,300 dry
39 Unlimited is offline
