27 fever prop for salt water stock setup >
Old 10-10-2014 | 01:19 PM
Default 27 fever prop for salt water stock setup
buying a 27 fever that has a 25 3 blade on it fresh water boat stock 502, The boat now will be in salt water like to know the best prop or what it came with stock
Dpad is offline
Old 10-10-2014 | 04:08 PM
probably came with 4 blade hydromotive or bravo prop depends on what year boat. depending on gears in drive a 26p-28p. The 3 blade will have more top end but will be a dog out of the hole
Bama is offline
Old 10-12-2014 | 10:26 AM
Call Fountain, they can tell you what prop was on the boat when it left the factory.
Cole2534 is offline
Old 10-13-2014 | 02:04 PM
anyone have a number for them this is my first Fountain
Dpad is offline
Old 10-13-2014 | 02:20 PM
252-975-2000 they answer the phone Baja now which is pretty lame.
RiReuter is offline
Old 10-15-2014 | 11:35 AM
What year is it? 502 mag mpi or carb?
ealesh33 is offline
Old 10-15-2014 | 12:57 PM
2001 502 mpi
Dpad is offline
Old 10-15-2014 | 01:07 PM
Its definitely a test and see with any boat, but a 24p bravo 1 will probably be where you are at. pretty sure they had raised the X dimension somewhere in the 98-00 area, and the bravo's became the more efficient prop. Test the 24p bravo 1 and a 24p hydro and see which one does what for you. An un altered hydro is usually a little tougher to plane, cruise speed is 1-2mph less, but out performs on the top end. If you have a higher X then the hydro will blow out most likely trying to plane. I have tested bravo 1 and hydro on my 27 fever with a 525sc. The hydro is labbed for a fountain. The hydro in my application was pretty much identical cruise, and 2.5ish mph faster up top. Boat is less likely to chine I have noticed with the hydro as well. It will still chine at 75-76 if I trim to fast, or tabs aren't set right, but if everything is done right it rides rock solid all the way up to 80mph, not sure about faster as the best I have done is 80.9
ealesh33 is offline
