What kind of outdrive is this? >
Old 10-11-2014 | 01:57 PM
phughes69's Avatar
Default What kind of outdrive is this?
I may be looking at a 1978 Python that the seller says has a speedmaster drive on it and the boat was set up for a BBC
What kind of outdrive is this and how much power can it hold. I'm thinking of putting a 330 HP twin turbo SBC in it that I have.[ATTACH=CONFIG]530816[/ATTACH]
Attached Thumbnails What kind of outdrive is this?-00j0j_2fwmcyblygr_600x450.jpg
phughes69 is offline
Old 10-11-2014 | 02:25 PM
my GUESS is sternpower. They were supposed to be good drives, but if you blow it, how are you ever going to get parts when you cant even google a pik of the thing??
phragle is offline
Old 10-11-2014 | 03:22 PM
Mbam's Avatar
Offshoreonly Advertiser
Can you get a closer shot of the transom assembly on the outside and inside the boat also?
Mbam is offline
Old 10-11-2014 | 04:17 PM
Drake22.250's Avatar
Volvo with a speed master foot? If it is very rare and no parts.
Drake22.250 is offline
Old 10-11-2014 | 04:28 PM
Older volvos didnt use that type of trim cylinders....
phragle is offline
Old 10-11-2014 | 07:49 PM
Looks like a speedmaster 3. Definitely a 3 lower. I know that cause I have one for decoration.
Eliminatorshane is offline
Old 10-11-2014 | 07:56 PM
14/15 or mc-1 . Under the cav plate the 14/15 has kind of a box about 4 inches wide and down the back towards propshaft is thin. A mc-1 has a box about 5 to 6 under cav plate and a thick back towards propshaft. Hope this helps or I'm close.
Old 10-11-2014 | 11:47 PM
Looks like a Mercruiser Model 2. My 1969 Sea Ray Pachanga had one from the factory. It was changed out in the late 70's for a pre alpha.
1969pachanga is offline
Old 10-12-2014 | 02:50 AM
obnoxus's Avatar
Charter Member #1171
Little off your topic,,,,, but a twin turbo small block with only 330 HP??????
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 10-12-2014 | 05:37 AM
phughes69's Avatar
Obnoxus, the engine is out of another hull I got. The engine is a 1979 260 hp sbc with a M&W turbo kit on it. According to the literature I found it only adds 50hp to the base engine. I ran the boat yesterday for the 1st time and was seeing 4lbs of boost. It is a blow thru carbed system. It designed to be pretty tame so not much modification has to be done on the engine.
