changing throttle shifter configeration  on Gaffrig >
Old 10-13-2014 | 02:33 PM
Default changing throttle shifter configeration on Gaffrig
I have a set of nice gaffrig throttles and shifters that are two separate units 2 throttles 2 shifters. my Question is can I buy a section from gaffrig and bolt them into one unit for my current project. or am I stuck with how they are
finishline is offline
Old 10-13-2014 | 10:39 PM
I have the mercruiser zero effort. I know they were sold by others but not sure if they are same as you have. I order pieces and they were cheap. Matter of fact, I have extras now if it turns out they are the same.
ttrm007 is offline
Old 10-14-2014 | 01:45 AM
That probably depends on if they are still making that model.
BTW, the Gaffrig controls you have are most likely actually Livorsi.
There used to be 2 Gaffrig companies and one had to change its name to Livorsi.
Griff is offline
Old 10-15-2014 | 07:23 AM
Great question i have the same set and was wondering the same thing also noticed the gafferig and livorsi had same part # ,will have them on bench today but it looked like they could be combined depending on the orientation of the end piece that contained the threads that hold the 5 long screws that hold it all together
airjunky is offline
Old 10-15-2014 | 10:18 PM
I think with the addition of another middle part and lose the ends on each set it would work now to find the part!
