4000 HP Shoell DDC 85' bow rider? >
Old 10-19-2014 | 08:01 AM
Default 4000 HP Shoell DDC 85' bow rider?
http://www.yachtworld.com/boats/2004...s#.VEO1XfnF_1g
Four C-18 CATS = 4,000 HP + 4,000 Gals = Great Performance & Great Range - See "Performance Stats" - in DESCRIPTION Section.
The Patented "Delta-Conic" Hull is efficient and provides a great ride in all sea-states...
Cruising comfortably at 32 knots, with a top speed of 45 knots, plus a 4,000 fuel capacity, gives the owner more range & comfort than most of the comparable 80-foot "Offshore" hulls on the market today.
With 360-degree visibility at the Helm, and four (4) C-18 CAT'S - For a total of over 4,000 HP- with ARNESON Surface Drives, you are really the Master of your Cruising Destiny.
Jupiter Sunsation is offline
Old 10-19-2014 | 08:15 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
That's the one and only 85' Active Thunder.
Just kidding.
Harry has built a handful of one-off boats over the years. He has a 47' or so that is also pretty awesome. Do a little digging, and you might find some similar lines to another DDC boat he designed.
Sydwayz is offline
Old 10-19-2014 | 01:55 PM
Poor color choice. Owner must be "new money" haha
scarab63 is offline
Old 10-19-2014 | 03:14 PM
Paint "Baywatch" on the side in red and sell it to Hasselhoff....
Also, they forgot the "c" in Schoell. I was all set to submit an offer, but I rarely buy 7mm dollar yachts from brokers that CAN'T SPELL.
Speedracer29 is offline
Old 10-19-2014 | 03:35 PM
glassdave's Avatar
Neno the mind boggler
I dont think i have ever seen a boat that screamed "DOCK PARTY!!!" more then that
08 OPA High Points Champion
glassdave is offline
Old 10-19-2014 | 03:38 PM
The yacht is here on the Chesapeake Bay....drejustice keeps his new Active Thunder at his Marina, so there are 2 there Brian!!!
http://www.pleasurecovemarina.com
Spicy is offline
Old 10-19-2014 | 06:16 PM
For almost 7mm I could probably buy ever AT Pat has built!
This is a goofy boat and not a single engine room pic!
Old 10-19-2014 | 06:29 PM
Also, just noticed rear deck.
Pretty dam cool to party on, or maybe put a couple jet skis on. But also a good way for those surface drives to chop your nads off if you are back there while under way and lose footing.
No rails, cables, nothing! !
scarab63 is offline
Old 10-19-2014 | 07:11 PM
Pretty cool. The layout is quite unique and it looks awesome for partying. Didn't exactly turn out pretty though.
hogie roll is offline
Old 10-19-2014 | 08:01 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I think a coat of dark blue or charcoal metallic paint would do wonders for it; replacing all of the Baywatch yellow.
Sydwayz is offline
