gen6 blocks, 548CI rotating assembly, cams...
For sale gen6 blocks one had a rod fail did not hurt block, couple chips in oil pan rail no big deal, they are 4.530 now should clean up, can go bigger with sonic testing cylinders to be sure. Have 2 blocks 750.00 each pick up only 44138 ohio
PBM/scat rotating assembly
4.25 stroke forged crank
6.385 scat h beam rods
SRP 4.530 pistons some have scuffs and were somehow touching counterweight on crank, I have 12 piston and rods to chose from I can send best ones. I would cut crank 0.010 to make sure scuffs are gone
Rotating assembly 800.00 plus ship
If you want all 12 rods and pistons (extra from bad engine) add 150.00 for the extra 4.
Erson roller custom cams one has more wear then other, I replaced one after a lifter failed last season so it's newer
114lca .236/[email protected] .578 lift
175.00 plus ship for roller cams each
Lifter sets 50.00 each set
Located in Olmsted falls Ohio for pick up 440-476-4114
[ATTACH=CONFIG]531295[/ATTACH][ATTACH=CONFIG]531296[/ATTACH][ATTACH=CONFIG]531297[/ATTACH][ATTACH=CONFIG]531298[/ATTACH][ATTACH=CONFIG]531299[/ATTACH][ATTACH=CONFIG]531300[/ATTACH]
