Fountain Fever 27 1996 >
Old 10-23-2014 | 10:37 AM
Default Fountain Fever 27 1996
Hi
Iam new to this Forum... im willing to buy a 1996 Fountain Fever 27... i have a new 540ci 600hp engine and bravo one X drive... Can someone tell me about this setup? and what would you guys suggest a prop for this boat? any answers about top speed? i live in Eu its Salt water over here
FountainFEVER 27 is offline
Old 10-24-2014 | 06:39 PM
I think a B1 28 would probably be what you need if you have a 1.5:1 drive. Speed, around 80mph.
badluck is offline
Old 10-24-2014 | 08:37 PM
Carbon Footprint's Avatar
I had a Hydromotive 25p spinning 5,000 rpm behind a 502mpi with cmi exhaust (probably 425hp) and hit 70 gps.
I agree that a 28 will probably be about right and low 80s
The Hydromotives do seem to work better on the 27 fever than the bravo 1 though.
Carbon Footprint is offline
Old 10-25-2014 | 03:08 AM
Okmany thanks for your help guys this week im going to see the boat and if it will be in good condition im gonna buy it... my drive is 1.5 gear ratio.... exhaust on my engine are Eddie marine manifolds with dry tail pipes..... just another question do you guys think that in salt water the boat will runn a little mph less than a boat in fresh water?
Old 10-25-2014 | 07:16 PM
The opposite, salt should be a tad faster.
badluck is offline
Old 10-26-2014 | 06:41 AM
Ok then thanks for your help some people over here say that boats in fresh water run faster than in salt... just another question please is lucas oil Sae 50 is good for marine engines... what oil viscosity do you suggest please?
Old 10-26-2014 | 05:58 PM
Too Stroked's Avatar
Just thought I'd add that every 27' Fountain we ever got from the factory came with a left hand rotation prop.
Too Stroked is offline
Old 10-26-2014 | 07:12 PM
First don't run a straight 50wt oil... i wouldn't run Lucas oil period. Look at widely available testing and you will see why. There are much better products out there. My recommendation is run a multi viscosity ie 10-40 15-40 synthetic oil and change it at proper intervals.
Borgie is offline
Old 10-28-2014 | 12:08 AM
funny you would ask about oil JIM.that is your name no?
mike tkach is offline
Old 10-28-2014 | 12:09 AM
for the first time in a while my RADARR is going off!
