1993 Awesome 320 468s bravo part out >
Old 10-24-2014 | 06:22 AM
Sick Stinger's Avatar
Brotherhood #1
Default 1993 Awesome 320 468s bravo part out
[ATTACH=CONFIG]531469[/ATTACH][ATTACH=CONFIG]531468[/ATTACH][ATTACH=CONFIG]531470[/ATTACH][ATTACH=CONFIG]531471[/ATTACH][ATTACH=CONFIG]531472[/ATTACH]
Here is another part out
32 93 Awesome powerboat all fresh water boat
468 gen V motors 4 bolt mains roller motors lunati cranks dimple rods federal mogul pistons double roller chains 8 Qts pans crane rockets crane cams 088 heads aluminum valve covers HP500 carbs Victor JR intakes stainless marine cross overs Stainless marine exhaust make 505 HP conservative can bump it easy
6200 plug and play 40 hours on motors
5500 less exhaust
1200 each exhaust set up if not sold with motors
1300 1.5 bravos gone threw with 40 hours skegs ahh
Bolster 1300 push button drops
K Planes complete 1200
Controls with cables 350
Gimbals 700 each
3000 each bravo conversion , includes every thing needed to swap
Gauge set Faria stuff 350 included wheel
150 each trim pump
65 each batt box
400 mirage 25p 3 blades
250 Bravo tie bar set up
3700 03 nextrail trailer 10500 gvw
Hull is Kevlar stripped out cabin floor is spongy the stringers deck hull other wise dry and solid.
I'll post other small stuff as I come across and pull.
Boat will be here next Sunday. I have vid of motors running
Attached Thumbnails 1993 Awesome 320 468s bravo part out-image.jpg   1993 Awesome 320 468s bravo part out-image.jpg   1993 Awesome 320 468s bravo part out-image.jpg
Sick Stinger is offline
Old 10-24-2014 | 10:11 AM
hey Mike am I supposed to stand on my head to look at these? lmao
adk61 is offline
Old 10-24-2014 | 10:41 AM
Brotherhood #1
Sorry Just the way they came threw
Price is for each Motor
Less if bought together as a pachage deal W/ W/O exhaust
Old 10-24-2014 | 11:46 AM
Good lookin lines on the hull What is it a splash of ?
tommymonza is offline
Old 10-24-2014 | 12:20 PM
Brotherhood #1
Not sure really, possibly a signature hustler
Old 10-24-2014 | 01:18 PM
No pad on the bottom.Definitely looks as if the 27 Mag was where it came from many molds ago which the hustler did also. Where were they built is that the same Awesome as ClemJim?
Old 10-24-2014 | 01:33 PM
Brotherhood #1
Built in Michigan I'm told
Brotherhood #1
I was told fountain came from this mold
Old 10-24-2014 | 02:04 PM
Nice lines on the hull . Be very sleek looking if you retooled a flatdeck for it
Maybe before they glued the beak on and added a pad but that would predate Excalibur where I believe the 1st Fountain originally came from
