how  to  remove gas overflow stain  side  of  boat? >
Old 10-25-2014 | 07:03 PM
26sonic's Avatar
Default how to remove gas overflow stain side of boat?
didnt realize but gas must have came out vent when i put boat away last wk i'm sure didnt over flow tank , what should i use to remove it? tried solvents, polishing compound still not coming out 100% on whit area!
26sonic is offline
Old 10-25-2014 | 08:31 PM
You`re looking at a repaint, couple of friends had the same problem .
ICDEDPPL is offline
Old 10-26-2014 | 12:45 PM
seltzer's Avatar
Yep. I had the same thing happen to me. Try wet sanding and buffing. If no luck, find a good paint shop.
seltzer is offline
Old 10-26-2014 | 12:47 PM
I had some luck with acetone. Be sure to clean and wax after.
Baja Rooster is offline
Old 10-26-2014 | 02:37 PM
Craney's Avatar
Is it paint or gel ?
Craney is offline
Old 10-27-2014 | 03:42 AM
26sonic's Avatar
its paint with clear coat over it.
26sonic is offline
Old 10-27-2014 | 08:25 AM
sounds like the gas ate into the clear because just ran down it for a long period of time...try water sanding and buffing..just depends on how bad it ate into the clear...never fill the fuel tank in the fall...get hot then expands and is forced out the vents...can't tel you how many stripes we have had to replace from the same deal..
ezstriper is offline
