Go Back  Offshoreonly.com > Owners Forum > Powerquest
Type of Steering System >
Old 10-26-2014 | 04:37 PM
Default Type of Steering System
Can someone please let me know what type steering system I have on my 29 foot 1999 Powerquest Enticer FX. There is about a 4 inch side to side play in the steering wheel and I am trying to find out what could be causing it and if there is a way to adjust the play in the wheel.
Sorceress is offline
Old 10-26-2014 | 06:54 PM
Your gimbal and swivel pin is most likely worn out.
payuppsucker is offline
Old 10-27-2014 | 05:55 AM
The play is in the steering wheel up front. When it moves left to right I have about a totla of 4 inches of play before I actually see any pressure applied to the cable connection at the motor. Would that still mean my gimbal and swivel pin is worn out?
Old 01-18-2015 | 08:32 PM
what did you end up finding/doing with this ssue
nitrouspaul is offline
Old 01-19-2015 | 06:54 PM
My dealer had to replace the steering box and cable. Now there is no play. Glad I had it done.
Old 06-07-2015 | 07:29 PM
Ended up having the steering box replaced by the dealer. That took care of the play. The problem now is that the steering effort has increased quite a bit. That still needs to be sorted out.
