2 Complete sets of EMI Thunder BBC Manifolds and risers. >
Old 10-27-2014 | 07:04 PM
Registered User
Default 2 Complete sets of EMI Thunder BBC Manifolds and risers.
Here are two complete sets of EMI Thunder manifolds Big Block Chevy and risers that have only been used in fresh water and are in perfect condition. They were in a 41 Apache staggared set up and they are 32.5 on center. [ATTACH=CONFIG]531607[/ATTACH][ATTACH=CONFIG]531606[/ATTACH][ATTACH=CONFIG]531605[/ATTACH][ATTACH=CONFIG]531608[/ATTACH][ATTACH=CONFIG]531609[/ATTACH][ATTACH=CONFIG]531610[/ATTACH]Asking 3000.00 for both sets plus shipping please call with questions as I am working in my shop all day and don't check for messages on OSO very often. 928-208-0702
Attached Thumbnails 2 Complete sets of EMI Thunder BBC Manifolds and risers.-dscf2433.jpg   2 Complete sets of EMI Thunder BBC Manifolds and risers.-dscf2434.jpg   2 Complete sets of EMI Thunder BBC Manifolds and risers.-dscf2435.jpg
2 Complete sets of EMI Thunder BBC Manifolds and risers.-dscf2436.jpg   2 Complete sets of EMI Thunder BBC Manifolds and risers.-dscf2437.jpg   2 Complete sets of EMI Thunder BBC Manifolds and risers.-dscf2438.jpg
havasubrian is offline
Old 10-29-2014 | 07:18 PM
Registered User
TTT I will take offers on these need to move them soon!
Old 10-30-2014 | 04:23 PM
will these fit standard bravo set ups through the transom?
intimid8 is offline
Old 10-30-2014 | 08:53 PM
By the pics it looks like manifolds will work but not risers. Im interested also in this set and his response.
1badchopper is offline
Old 11-01-2014 | 11:20 PM
Registered User
I showed that they are 32.5 center to center and they had dry pipes on them so not set up for slip on hoses as you can see in the picture so not sure what you are actually asking Intimid8 I can take what ever measurements you need for them. If your trying to use the risers for hoses to tips the risers wouldn't work. I will make you a deal!
Old 11-04-2014 | 09:14 AM
Registered User
Ttt
Old 11-04-2014 | 01:33 PM
my problem is I am far from a gear head. I want something that will fit my boat which is a twin engine fountain 32 with bravos. Engines were 502's and the new ones are 540's so I assume the position to the tail pipes have not changed. I don't want to modify anything I just want a plug and play solution. If these will fit without cutting or welding etc.. I am very interested. I look forward to your reply.
intimid8 is offline
Old 11-05-2014 | 06:49 PM
Registered User
These will work if you have the other risers that you need for them and eddie marine has those so it would be plug and play. So you could just get the risers from him for this set and work.
Old 11-18-2014 | 06:59 PM
Call me tony 302-690-9884
tonymalec550 is offline
