I need a gen v 502 block
Old 10-28-2014 | 08:50 AM
From: Central Square & Fishers Landing, 1000 Islands NY
Default I need a gen v 502 block
Just like it says. Torched a head and block when I pushed a head gasket out. Anyone have a Gen V 502 block near NY? No junk!
1000 islander is offline
Old 10-28-2014 | 09:51 AM
I have a gen 5, if you can find a gen 6 I'd swap it so I have a matched pair.
Unlimited jd is offline
Old 10-28-2014 | 11:51 AM
You may be able to have the block welded up between the cylinders. I have done this a few times with race car blocks that I had lots of time or money in with no ill effects.
snapmorgan is offline
Old 10-28-2014 | 01:35 PM
Gonna deck this one .010 and see what it looks like. Its right near the rear head bolt and right in a head gasket water passage. Here's a nice pic of the junk head.
[ATTACH=CONFIG]531649[/ATTACH]
Attached Thumbnails I need a gen v 502 block-10628206_10205067413271713_5918270405788217601_n.jpg
Old 10-28-2014 | 01:39 PM
OUCH, but at least you didn't have to guess what the problem was.
Old 10-28-2014 | 01:42 PM
Damn that was pretty severe! What was the motor?
Old 10-28-2014 | 02:25 PM
Some JB weld and good to go......
wannabe is offline
Old 10-28-2014 | 02:30 PM
HP500 with Edelbrock aluminum heads. Lucky it didn't catch boat on fire. It burned the bilge blower ducting! When I felt it lose power I quick shut that motor down. I stayed up on plane with the other two motors for another 18-20 miles. That musta forced water thru the drive and motor and sprayed out this gash putting any fire out. Wondered why bilge pump light kept coming on! I boated the whole next day on the port and center motor.
Old 10-28-2014 | 05:55 PM
it looks as though they are the standard felpro head gaskets vs MLS. what rpm were you at and what was the water pressure reading. what water temperature does it usually run?
BLUEMAGIC is offline
Old 10-29-2014 | 06:31 AM
I was wide open at around 5,100 rpms at around 20-22 psi and 160 degrees water temp. Not sure what the head gaskets were but all three motors are being gone thru as we speak and will have MLS gaskets. Waiting to hear back from Bob Madera because I am thinking about going to 540's with new cams.
